Zum Hauptinhalt wechseln
Coby DVD209 4-Pin Ribbon Cable Replacement
Was du brauchst
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: Schritt 1, Bild 1 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: Schritt 1, Bild 2 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: Schritt 1, Bild 3 von 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: Schritt 2, Bild 1 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement: Schritt 2, Bild 2 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: Schritt 3, Bild 1 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement: Schritt 3, Bild 2 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement: Schritt 3, Bild 3 von 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: Schritt 4, Bild 1 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: Schritt 4, Bild 2 von 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: Schritt 4, Bild 3 von 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Yufay Chow
92 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 10-36, Amido Winter 2012 Mitglied von Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 1,010
