Was du brauchst
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
Pry the top of the device open from the right side where the buttons are located.
Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Position the DVD player so that the power and AVI ports are facing you.
Pull the white cable with the blue adapters off of the circuit boards.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
