Zum Hauptinhalt wechseln
Coby DVD209 Circuit Board for Buttons Replacement
Was du brauchst
  1. Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: Schritt 1, Bild 1 von 3 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: Schritt 1, Bild 2 von 3 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Circuit Board for Buttons Replacement: Schritt 2, Bild 1 von 3 Coby DVD209 Circuit Board for Buttons Replacement: Schritt 2, Bild 2 von 3 Coby DVD209 Circuit Board for Buttons Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Circuit Board for Buttons Replacement: Schritt 3, Bild 1 von 3 Coby DVD209 Circuit Board for Buttons Replacement: Schritt 3, Bild 2 von 3 Coby DVD209 Circuit Board for Buttons Replacement: Schritt 3, Bild 3 von 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: Schritt 4, Bild 1 von 2 Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: Schritt 4, Bild 2 von 2
    • Take the top portion of the DVD player and orient the device as shown in the first picture.
    • Remove the four 0.2" screws circled in red.
  5. Coby DVD209 Circuit Board for Buttons Replacement: Schritt 5, Bild 1 von 3 Coby DVD209 Circuit Board for Buttons Replacement: Schritt 5, Bild 2 von 3 Coby DVD209 Circuit Board for Buttons Replacement: Schritt 5, Bild 3 von 3
    • Losen the screw circled in red.
    • The screw will not come out of the plastic knob.
    • Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
Abschluss
Yufay Chow
92 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 10-36, Amido Winter 2012 Mitglied von Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 436
