Einleitung
If your Asus Eee PC 900 LCD display screen is damaged, experiencing pixel issues, or is dim in a bright background, use this guide to replace your display screen.
Prior to making this repair, it is important to confirm that the replacement itself is necessary. Check to make sure that no other solutions are viable. For problems such as pixel issues, inverter issues, or not being able to see color, a full replacement may be necessary.
This guide requires you to remove the battery, keyboard, top cover, and LCD display screen from your Asus Eee PC 900. Some steps require the use of a spudger.
Before beginning, make sure to completely power down the device and disconnect from any external power source.
Was du brauchst
Slide the battery's locking tabs from the locked position to unlocked positions.
Slide the battery out while holding the left locking tab in the unlocked position.
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
Slide the keyboard's ribbon cable from the connector.
Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
Flip the laptop back over and identify the touchpad ribbon.
Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
Gently pry off the six rubber covers around the outside of the screen using a two mm flat head screwdriver.
Remove the six 4.76 mm Phillips #0 screws underneath each cover.
Using a plastic opening tool, carefully detach the casing around the screen cover.
Remove the screen cover.
Remove the four 4.76mm Phillips #0 screws located on the corners of the screen.
Lift out the display screen.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Perfect guide, thank you.
