Zum Hauptinhalt wechseln
Sony M-430 Microcassette-Corder Back Cover Replacement
Was du brauchst
  1. Sony M-430 Microcassette-Corder Back Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Back Cover Replacement: Schritt 2, Bild 1 von 2 Sony M-430 Microcassette-Corder Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: Schritt 3, Bild 1 von 2 Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Back Cover Replacement: Schritt 4, Bild 1 von 2 Sony M-430 Microcassette-Corder Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Back Cover Replacement: Schritt 6, Bild 1 von 1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Matt Teare
35 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-34, Amido Winter 2012 Mitglied von Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 2,059
