Einleitung
This guide is for the removal and installation of new track pad and palm rest of the Dell Latitude X300
Was du brauchst
Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
Carefully turn the laptop over and open the screen all the way.
Locate the slot to remove the keyboard in the lower left hand corner.
Using a spudger as a lever, insert it into the slot and gently pry up.
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Position the laptop so that the bottom is facing upward.
Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
Return the laptop to proper position and open the screen.
Remove the six 4 mm Phillips #0 screws holding in the palm rest.
Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
