Zum Hauptinhalt wechseln
Dell Latitude X300 Keyboard Replacement
Was du brauchst
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  2. Dell Latitude X300 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Latitude X300 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Abschluss
Jacob Egorov
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 11-20, Maness Winter 2012 Mitglied von Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,241
