Dell Latitude X300 Built-In Speakers Replacement
  1. Dell Latitude X300 Built-In Speakers Replacement, Battery: step 1, image 1 of 1
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Dell Latitude X300 Built-In Speakers Replacement: step 2, image 1 of 1
    • Slide the battery out of the laptop.
  3. Dell Latitude X300 Built-In Speakers Replacement, Keyboard: step 3, image 1 of 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  4. Dell Latitude X300 Built-In Speakers Replacement: step 4, image 1 of 2 Dell Latitude X300 Built-In Speakers Replacement: step 4, image 2 of 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. Dell Latitude X300 Built-In Speakers Replacement: step 5, image 1 of 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Dell Latitude X300 Built-In Speakers Replacement: step 6, image 1 of 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  7. Dell Latitude X300 Built-In Speakers Replacement: step 7, image 1 of 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  8. Dell Latitude X300 Built-In Speakers Replacement, Palm Rest/Track Pad: step 8, image 1 of 1
    • Position the laptop so that the bottom is facing upward.
    • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
  9. Dell Latitude X300 Built-In Speakers Replacement: step 9, image 1 of 1
    • Return the laptop to proper position and open the screen.
    • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
  10. Dell Latitude X300 Built-In Speakers Replacement: step 10, image 1 of 1
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  11. Dell Latitude X300 Built-In Speakers Replacement: step 11, image 1 of 1
    • Lift up on the small ZIF connector and remove the ribbon.
    • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
  12. Dell Latitude X300 Built-In Speakers Replacement, Built-In Speakers: step 12, image 1 of 1
    • Remove the #00 4 mm screws holding the speakers in place.
  13. Dell Latitude X300 Built-In Speakers Replacement: step 13, image 1 of 1
    • Gently pull the speaker cable out.
    • If the wire is tight, wiggle it back and forth but don’t apply too much force.
    • Do not use the speaker wire to pull itself out of the connector.
  14. Dell Latitude X300 Built-In Speakers Replacement: step 14, image 1 of 1
    • Pull the speakers straight up and out of the laptop.
Elai Fresco
7 Reputation
2 Guides authored
Cal Poly, Team 11-20, Maness Winter 2012 Member of Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 995
