Zum Hauptinhalt wechseln
Sony DVP-FX730 Screen Replacement
Was du brauchst
  1. Sony DVP-FX730 Screen Replacement, Monitor: Schritt 1, Bild 1 von 2 Sony DVP-FX730 Screen Replacement, Monitor: Schritt 1, Bild 2 von 2
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: Schritt 2, Bild 1 von 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: Schritt 3, Bild 1 von 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: Schritt 4, Bild 1 von 2 Sony DVP-FX730 Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: Schritt 5, Bild 1 von 2 Sony DVP-FX730 Screen Replacement: Schritt 5, Bild 2 von 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: Schritt 6, Bild 1 von 1
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: Schritt 7, Bild 1 von 1
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: Schritt 8, Bild 1 von 1
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: Schritt 9, Bild 1 von 1
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: Schritt 12, Bild 1 von 2 Sony DVP-FX730 Screen Replacement: Schritt 12, Bild 2 von 2
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: Schritt 13, Bild 1 von 2 Sony DVP-FX730 Screen Replacement: Schritt 13, Bild 2 von 2
    • Place your hand on the front of the screen and push upwards.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 11-21, Maness Winter 2012 Mitglied von Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 2,714
