Einleitung
If the device is on but nothing shows up on the screen, the screen may need to be replaced.
Was du brauchst
Referring back to Step 8, do the same with the wires attached to the black base.
Remove the four rubber feet and the screws beneath.
Remove the two exposed screws on the left side.
Pull back the cables until the screw is visible.
Using spudger, push the lock clips to unlock the ribbon cable.
Using tweezers, pull the connector loose.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
