Zum Hauptinhalt wechseln
Motorola Droid RAZR Back Cover Replacement
Was du brauchst
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Droid RAZR Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: Schritt 2, Bild 1 von 3 Motorola Droid RAZR Back Cover Replacement: Schritt 2, Bild 2 von 3 Motorola Droid RAZR Back Cover Replacement: Schritt 2, Bild 3 von 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: Schritt 3, Bild 1 von 3 Motorola Droid RAZR Back Cover Replacement: Schritt 3, Bild 2 von 3 Motorola Droid RAZR Back Cover Replacement: Schritt 3, Bild 3 von 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.503 Reputation
127 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 14,228
