Einleitung
Replace a cracked or broken camera cover with a shiny new one.
Was du brauchst
Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
Pry the back cover up with the plastic opening tool to free the plastic clips.
Continue prying along the left edge of the back cover towards the top of the phone.
Work the plastic opening tool across the top of the back case to free the plastic clips.
Continue prying down the right side of the back cover to free the remaining clips.
Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
Remove the two 3.3 mm T5 Torx battery terminal screws.
Grab the blue battery removal tab and lift the battery out to remove it.
Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
Gently pry up the bottom edge of the camera cover with a plastic opening tool.
Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
Insert the plastic opening tool underneath the top edge of the camera cover.
Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
Remove the camera cover.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
