Zum Hauptinhalt wechseln
PlayStation Vita Wi-Fi Antenna Replacement
Was du brauchst
  1. PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: Schritt 1, Bild 1 von 2 PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: Schritt 1, Bild 2 von 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 2, Bild 1 von 3 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 2, Bild 2 von 3 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 3, Bild 1 von 2 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 4, Bild 1 von 3 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 4, Bild 2 von 3 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 4, Bild 3 von 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 5, Bild 1 von 2 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 7, Bild 1 von 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and rear cases.
  9. PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: Schritt 9, Bild 1 von 2 PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: Schritt 9, Bild 2 von 2
    • Using the pointy end of a spudger, gently pry the white Wi-Fi antenna cable connecotr off of the wireless card.
    • Deroute the Wi-Fi antenna cable out of the black plastic casing.
  10. PlayStation Vita Wi-Fi Antenna Replacement: Schritt 10, Bild 1 von 2 PlayStation Vita Wi-Fi Antenna Replacement: Schritt 10, Bild 2 von 2
    • Using the pointy end of the spudger, gently pry the Wi-Fi antenna cable connector off of the left button board at the connection.
    • Remove the Wi-Fi antenna cable.
Abschluss
Brittany McCrigler
88.898 Reputation
131 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
16.576 Anleitungen geschrieben
4 Kommentare
what about the ps vita slim 2000 model? ive got no wifi at all but cant see a teardown to find the wifi module
Keegan - Antwort
Is WiFi / 3G antenna cable: UFL/IPEX to UFL/IPEX 1.3mm? What is the white cable length?
samohvalov2010 - Antwort
Yeah this is not a Wifi antenna cable. The "wireless card" only does 3G and GPS/Glonass. Wifi controller is on the mainboard itself.
computer1up - Antwort
^ okay that explains a lot, i thought i was missing parts in my PSV1000 wifi
Bronson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 15
Letzte 30 Tage: 64
Insgesamt: 8,283
