Zum Hauptinhalt wechseln
Motorola Droid RAZR Antenna/Headphone Jack Replacement
Was du brauchst
  1. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 2, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 2, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 2, Bild 3 von 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 3, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 3, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 3, Bild 3 von 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
  4. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Battery: Schritt 4, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
  5. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 5, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 5, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 3.3 mm T5 Torx battery terminal screws.
    • Grab the blue battery removal tab and lift the battery out to remove it.
    • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
    • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
  6. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Camera Cover: Schritt 6, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Camera Cover: Schritt 6, Bild 2 von 2
    • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
    • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
    • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
    • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
    • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
  7. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 7, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 7, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 7, Bild 3 von 3
    • Insert the plastic opening tool underneath the top edge of the camera cover.
    • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
    • Remove the camera cover.
  8. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Rear Case: Schritt 8, Bild 1 von 1
    • Remove the six screws securing the rear case to the rest of the phone:
    • three 6.7 mm silver T3 Torx screws at the top,
    • four 4.0 mm gold T3 Torx screws in the middle,
    • and three 4.5 mm black T5 Torx screws at the bottom.
  9. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 9, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 9, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 9, Bild 3 von 3
    • Insert a plastic opening tool between the rear case and the motherboard assembly.
    • Work your way down the side of the phone and gently pry the rear case up.
    • Separate the rear case from the motherboard assembly.
  10. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Motherboard Assembly: Schritt 10, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Motherboard Assembly: Schritt 10, Bild 2 von 2
    • Remove the three 2.5 mm T3 Torx screws securing the metal chassis to the motherboard.
    • Remove the metal chassis from the motherboard assembly.
  11. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 11, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 11, Bild 2 von 2
    • Use the flat end of a spudger to remove the two red silicone microphone covers at the top and bottom of the motherboard.
  12. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 12, Bild 1 von 1
    • There is a small metal shield that covers the display assembly cable connectors on the motherboard. This shield is held in place by a few small clips that attach to the surrounding EMI shields.
    • Use the tip of a spudger to gently bend the clips out of shape and remove the shield.
  13. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 13, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 13, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 13, Bild 3 von 3
    • Use the flat end of a spudger to pry the three display cable connectors off their sockets on the motherboard.
  14. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 14, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 14, Bild 2 von 2
    • There are a number of small black plastic clips on the display assembly that hold the motherboard in place.
    • Release the securing clips with a plastic opening tool.
  15. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 15, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 15, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 15, Bild 3 von 3
    • Use a heat gun or hair dryer to soften the adhesive strip around the perimeter of the motherboard.
    • Pry the edges of the motherboard up from the display assembly with a plastic opening tool.
    • Remove the motherboard assembly.
  16. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Rear-Facing Camera: Schritt 16, Bild 1 von 2 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Rear-Facing Camera: Schritt 16, Bild 2 von 2
    • Lift up the anti-static tape covering the camera and earpiece ZIF connectors with the tip of a spudger.
    • Peel back the tape and remove it.
    • Unless you have spare ESD-safe tape lying around, you may consider keeping this piece somewhere safe to be reused at reassembly.
  17. Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 17, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 17, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement: Schritt 17, Bild 3 von 3
    • Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
    • Make sure you're prying on the tab and not the connector itself.
    • Push the rear-facing camera through its hole in the grey antenna and remove it.
  18. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Front-Facing Camera: Schritt 18, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Front-Facing Camera: Schritt 18, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Front-Facing Camera: Schritt 18, Bild 3 von 3
    • Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector.
    • Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
  19. Motorola Droid RAZR Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: Schritt 19, Bild 1 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: Schritt 19, Bild 2 von 3 Motorola Droid RAZR Antenna/Headphone Jack Replacement, Antenna/Headphone Jack: Schritt 19, Bild 3 von 3
    • Insert a plastic opening tool between the antenna and motherboard near the micro USB and micro HDMI ports and pry the antenna free.
    • Remove the antenna from the motherboard.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.556 Reputation
127 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 32,248
