Zum Hauptinhalt wechseln
Blackberry Bold 9650 Back Chassis Replacement
Was du brauchst
  1. Blackberry Bold 9650 Back Chassis Replacement, Battery: Schritt 1, Bild 1 von 2 Blackberry Bold 9650 Back Chassis Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Back Chassis Replacement: Schritt 2, Bild 1 von 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Back Chassis Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Back Chassis Replacement: Schritt 4, Bild 1 von 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Back Chassis Replacement, Back Chassis: Schritt 5, Bild 1 von 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Back Chassis Replacement: Schritt 6, Bild 1 von 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Back Chassis Replacement: Schritt 7, Bild 1 von 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Back Chassis Replacement: Schritt 8, Bild 1 von 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan
696 Reputation
11 Anleitungen geschrieben
Clemson, Team 2-5, Benson Spring 2012 Mitglied von Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 3,174
