Zum Hauptinhalt wechseln
Samsung Galaxy Tab A 7.0 Battery Replacement
Was du brauchst
  1. Samsung Galaxy Tab A 7.0 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 3, Bild 3 von 3
    • Using tweezers, gently lift the black tab locking the wire connecting the battery to the motherboard.
    • Pull wire from connector.
    • This is the only connection for the battery to the motherboard.
  4. Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab A 7.0 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the device.
    • Separating tool may be needed in order to lift battery from device.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Bradley Watson
1.079 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 5-4, Passmore Spring 2017 Mitglied von USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Mitglieder
8 Anleitungen geschrieben
4 Kommentare
I found there was a layer of double-sided tape backing the battery, and I had to use a flathead screwdriver to get enough force to lever it up. This does not significantly change the guide.
brunius - Antwort
It would be nice if you showed which side to remove.
Bob White - Antwort
The OEM battery in my device expanded and pushed the screen from the housing. I had to temporarily separate the screen from the housing while leaving the connectors in their sockets while I pried the front housing from the back to reveal the battery. Once the front and back of the chassis were separated, I reattached the screen to the front housing and continued with the procedure. A heat gun made the process much easier by loosening the tape between the screen and housing, but was not necessary to lift the battery or separate the front from the back of the chassis.
Dan Murphy - Antwort
Bought a new battery, replaced as said, but seems like new battery is dead. How does one boost it? If I plug into charge, it almost seems like te sceen "flashes" but doesnt come on or show charge bar. Please help.
anciska.mills - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 80
Letzte 30 Tage: 373
Insgesamt: 18,092
