Zum Hauptinhalt wechseln
PowerBook G4 Titanium DVI Keyboard Replacement
Was du brauchst
  1. PowerBook G4 Titanium DVI Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 PowerBook G4 Titanium DVI Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  3. PowerBook G4 Titanium DVI Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
  4. PowerBook G4 Titanium DVI Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Your laptop should look approximately like this.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 10,646
