Zum Hauptinhalt wechseln
Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement
Was du brauchst
  1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement, Auxiliary Port: Schritt 1, Bild 1 von 1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert.
  2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding holding the battery on the device.
  3. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 3, Bild 3 von 3
    • Gently detach the set of wires clips connecting the battery to the device using a nylon spudger.
    • Remove the battery and set it aside.
  4. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  5. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 5, Bild 3 von 3
    • Locate the flex cables attached to the motherboard. Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp tools have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  6. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 6, Bild 3 von 3
    • Locate the yellow brackets at the bottom of the device.
    • Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port.
    • Lift the brackets from the device and set them aside.
    • You may need to use a nylon spudger, or any flat tool, to lift the brackets out of their place.
  7. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 7, Bild 1 von 1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small metal covering off of the auxiliary port.
    • This will reveal a rubber covering.
  8. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 8, Bild 1 von 1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small rubber covering to expose the auxiliary port.
    • This will reveal the auxiliary port.
  9. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: Schritt 9, Bild 1 von 1
    • Lift the auxiliary port with a nylon spudger.
    • Remove the auxiliary component.
    • It is easiest to lift this piece from the innermost side of the port, opposite of the opening.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Katija Tarailo
460 Reputation
3 Anleitungen geschrieben
IUPUI, Team S3-G1, Harley Spring 2017 Mitglied von IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 2,036
