Zum Hauptinhalt wechseln
Basis Peak Frame Replacement
Was du brauchst
  1. Basis Peak Frame Replacement, Frame: Schritt 1, Bild 1 von 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Frame Replacement: Schritt 2, Bild 1 von 2 Basis Peak Frame Replacement: Schritt 2, Bild 2 von 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Frame Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Frame Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
Abschluss
UMass Dartmouth, Team S4-G4, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G4, Julie Spring 2017
UMASSD-JULIE-S17S4G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 155
