Zum Hauptinhalt wechseln
Blackberry Bold 9650 LCD Screen Replacement
Was du brauchst
  1. Blackberry Bold 9650 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Blackberry Bold 9650 LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 LCD Screen Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 LCD Screen Replacement, Back Chassis: Schritt 5, Bild 1 von 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 LCD Screen Replacement, Mother Board: Schritt 9, Bild 1 von 1
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 LCD Screen Replacement: Schritt 10, Bild 1 von 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 LCD Screen Replacement: Schritt 12, Bild 1 von 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 LCD Screen Replacement, Faceplate: Schritt 13, Bild 1 von 2 Blackberry Bold 9650 LCD Screen Replacement, Faceplate: Schritt 13, Bild 2 von 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  14. Blackberry Bold 9650 LCD Screen Replacement, LCD Screen: Schritt 14, Bild 1 von 1
    • Turn the phone so it is facing up.
    • Use the plastic pry tool to gently pry out the screen.
    • The screen is glued to the phone so it may require some force to remove so use extra caution to prevent the screen from breaking.
  15. Blackberry Bold 9650 LCD Screen Replacement: Schritt 15, Bild 1 von 1
    • Lift the screen away from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan
696 Reputation
11 Anleitungen geschrieben
Clemson, Team 2-5, Benson Spring 2012 Mitglied von Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 8,505
