Zum Hauptinhalt wechseln
Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display
Was du brauchst
  1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Case: Schritt 1, Bild 1 von 1
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 2, Bild 1 von 2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 2, Bild 2 von 2
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 3, Bild 1 von 3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 3, Bild 2 von 3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 3, Bild 3 von 3
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
  4. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: Schritt 4, Bild 1 von 2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: Schritt 4, Bild 2 von 2
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  5. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 5, Bild 1 von 2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 5, Bild 2 von 2
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  6. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 6, Bild 1 von 3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 6, Bild 2 von 3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: Schritt 6, Bild 3 von 3
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
Abschluss
Clemson, Team 2-3, Benson Spring 2012 Mitglied von Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 1,662
