Zum Hauptinhalt wechseln
Canon EOS Rebel G Back Panel Latch Replacement
Was du brauchst
  1. Canon EOS Rebel G Back Panel Latch Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Latch Replacement: Schritt 2, Bild 1 von 2 Canon EOS Rebel G Back Panel Latch Replacement: Schritt 2, Bild 2 von 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Latch Replacement: Schritt 3, Bild 1 von 3 Canon EOS Rebel G Back Panel Latch Replacement: Schritt 3, Bild 2 von 3 Canon EOS Rebel G Back Panel Latch Replacement: Schritt 3, Bild 3 von 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Latch Replacement, Back Panel Latch: Schritt 4, Bild 1 von 1
    • Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Two 4.3 mm Phillips screws
  5. Canon EOS Rebel G Back Panel Latch Replacement: Schritt 5, Bild 1 von 1
    • Open the back panel by pushing the locking latch up.
    • Lift the latch cover off of the camera body.
  6. Canon EOS Rebel G Back Panel Latch Replacement: Schritt 6, Bild 1 von 1
    • Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Sometimes the latch will detach while pushing it up.
Abschluss
Zach
43 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Spring 2012 Mitglied von Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Mitglieder
36 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 25
Insgesamt: 2,553
