Zum Hauptinhalt wechseln
Casio Cassiopeia E-125 Touch Screen Replacement
Was du brauchst
  1. Casio Cassiopeia E-125 Touch Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 4, Bild 1 von 1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Touch Screen Replacement, Touch Screen: Schritt 5, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 6, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 7, Bild 1 von 1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 8, Bild 1 von 1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 9, Bild 1 von 1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 10, Bild 1 von 1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 11, Bild 1 von 2 Casio Cassiopeia E-125 Touch Screen Replacement: Schritt 11, Bild 2 von 2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
Abschluss
Cal Poly, Team 5-4, Forte Spring 2012 Mitglied von Cal Poly, Team 5-4, Forte Spring 2012
CPSU-FORTE-S12S5G4
6 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 979
