Zum Hauptinhalt wechseln
iHome iBT16 Motherboard Replacement
Was du brauchst
  1. iHome iBT16 Motherboard Replacement, Base Plate: Schritt 1, Bild 1 von 2 iHome iBT16 Motherboard Replacement, Base Plate: Schritt 1, Bild 2 von 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: Schritt 2, Bild 1 von 2 iHome iBT16 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 iHome iBT16 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 iHome iBT16 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: Schritt 4, Bild 1 von 2 iHome iBT16 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the plastic cover from the power switch actuator on the motherboard.
Abschluss
Joseph Hazel
329 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,129
