Zum Hauptinhalt wechseln
Casio Cassiopeia E-125 Motherboard Replacement
Was du brauchst
  1. Casio Cassiopeia E-125 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Motherboard Replacement, Touch Screen: Schritt 5, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 11, Bild 1 von 2 Casio Cassiopeia E-125 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
  12. Casio Cassiopeia E-125 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Locate the small grey ribbon cable towards the bottom of the device. It should be located above the battery slot. Pinch both sides of the ribbon cable and pull it out.
  13. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Locate the multicolored wire on the motherboard near the battery compartment. Pull on the wire by the base and lift to remove.
  14. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Use the Phillips #00 Screwdriver to remove the two screws from the green circuit board on the back case.
  15. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Remove the the three screws on the motherboard that are shown using the Phillips #00 Screwdriver.
  16. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Caution: do not break ribbon cables from the motherboard because this may cause damage to your device.
    • Flip the motherboard towards the front cover to expose the ribbon cables underneath.
  17. Casio Cassiopeia E-125 Motherboard Replacement: Schritt 17, Bild 1 von 2 Casio Cassiopeia E-125 Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Locate the two ribbon cables on the motherboard. Select one to remove first and then pinch either side of it and pull out to remove the ribbon cable. Do the same for the second.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 5-4, Forte Spring 2012 Mitglied von Cal Poly, Team 5-4, Forte Spring 2012
CPSU-FORTE-S12S5G4
6 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,159
