Zum Hauptinhalt wechseln
Dell XPS 12 9Q23 Touch Pad Replacement
Was du brauchst
  1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Touch Pad Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Touch Pad Replacement: Schritt 3, Bild 1 von 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Touch Pad Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: Schritt 5, Bild 1 von 1
    • Once all the screws have been removed the battery is now safe to extract
  6. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: Schritt 6, Bild 1 von 1
    • Unplug the trackpad cable.
  7. Dell XPS 12 9Q23 Touch Pad Replacement: Schritt 7, Bild 1 von 1
    • Insert wisdom here.
  8. Dell XPS 12 9Q23 Touch Pad Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 4 trackpad screws.
  9. Dell XPS 12 9Q23 Touch Pad Replacement: Schritt 9, Bild 1 von 1
    • Remove the trackpad.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
DJ Jackson
384 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,604
