Zum Hauptinhalt wechseln
Blackberry Curve 8330 LCD Panel Replacement
Was du brauchst
  1. Blackberry Curve 8330 LCD Panel Replacement, Remove Back Cover: Schritt 1, Bild 1 von 1
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 LCD Panel Replacement, Remove Battery: Schritt 2, Bild 1 von 1
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
  3. Blackberry Curve 8330 LCD Panel Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the two top screws using a T5 Torx screwdriver.
  4. Blackberry Curve 8330 LCD Panel Replacement: Schritt 4, Bild 1 von 2 Blackberry Curve 8330 LCD Panel Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
    • The cover will now pull off easily.
  5. Blackberry Curve 8330 LCD Panel Replacement: Schritt 5, Bild 1 von 2 Blackberry Curve 8330 LCD Panel Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to pry between the front and back cover.
    • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
    • There are 5 securing clips on the front panel to disconnect.
    • Pry gently to prevent breaking the plastic clips when removing the front panel.
    • Once all the clips have been freed, the front cover will lift away from the phone.
  6. Blackberry Curve 8330 LCD Panel Replacement: Schritt 6, Bild 1 von 1
    • Lift the flexible keypad away from the device. It should come off easily.
  7. Blackberry Curve 8330 LCD Panel Replacement: Schritt 7, Bild 1 von 2 Blackberry Curve 8330 LCD Panel Replacement: Schritt 7, Bild 2 von 2
    • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
    • Lift the keyboard frame away from the device.
    • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
  8. Blackberry Curve 8330 LCD Panel Replacement, LCD Panel: Schritt 8, Bild 1 von 2 Blackberry Curve 8330 LCD Panel Replacement, LCD Panel: Schritt 8, Bild 2 von 2
    • Detach each side casing by pulling them off gently from the phone.
  9. Blackberry Curve 8330 LCD Panel Replacement: Schritt 9, Bild 1 von 1
    • Remove the back housing from the mother board.
  10. Blackberry Curve 8330 LCD Panel Replacement: Schritt 10, Bild 1 von 1
    • Unhook the screen frame from the small tab at the top of the motherboard.
  11. Blackberry Curve 8330 LCD Panel Replacement: Schritt 11, Bild 1 von 2 Blackberry Curve 8330 LCD Panel Replacement: Schritt 11, Bild 2 von 2
    • Using a plastic opening tool, detach the connector on the LCD screen from the motherboard.
    • There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
    • Remove the LCD screen from the motherboard
Abschluss
Joshua Ramos
65 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-11, Forte Spring 2012 Mitglied von Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 1,569
