Zum Hauptinhalt wechseln
Dell Photo Printer 540 Case Replacement
Was du brauchst
  1. Dell Photo Printer 540 Case Replacement, Case: Schritt 1, Bild 1 von 1
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 Case Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 Case Replacement: Schritt 3, Bild 1 von 1
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 Case Replacement: Schritt 4, Bild 1 von 1
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 Case Replacement: Schritt 5, Bild 1 von 1
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 Case Replacement: Schritt 6, Bild 1 von 2 Dell Photo Printer 540 Case Replacement: Schritt 6, Bild 2 von 2
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
Abschluss
Cal Poly, Team 14-7, Forte Spring 2012 Mitglied von Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 642
