Einleitung
The Sony Nex-5t LCD screen may become worn, or broken through prolonged use. This guide will take you step by step through the disassembly of the Sony Nex-5t in order to replace the LCD screen.
Was du brauchst
Pick up the device with the LCD screen facing you.
While gripping with one hand, lift up on the LCD screen to reveal screws underneath
Remove the second plate by pulling it away from the camera. You can use tweezers or your fingers for this step.
Rotate the camera so the lens is facedown and the power button is pointing away from you.
Remove the two 1.2mm Phillips 00 screws shown in the image.
Rotate the camera, and lift up on the LCD screen.
This will reveal a large black rectangular film which you can peel back with tweezers.
Rotate the camera and use your fingers or tweezers to disconnect the first wire.
Lift the tab of the ZIF connector and pull the wire away from the motherboard.
You may remove the loose black film from the back of the LCD screen.
When purchasing a new LCD screen be mindful that some do not come with the original plastic frame. You may have to separate these pieces by pushing the LCD out of the frame from behind.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where does one find the replacement screen? I’m in sore need of this myself.
I was able to get the screen working with a new replacement, but without the double-sided tape it feels like a cludge.
where did you find the screen, if i may?
