Einleitung
This guide shows you how to install the grip on your camera.
Was du brauchst
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using your finger, peel back the textured grip so the components are separated.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
Use your fingers to pull out the plug that is located between the screw holes.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
