Zum Hauptinhalt wechseln
Motion Computing LE1600 Bluetooth Module Replacement
Was du brauchst
  1. Motion Computing LE1600 Bluetooth Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device so the screen is facing down.
  2. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 2, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 3, Bild 1 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 3, Bild 2 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 3, Bild 3 von 3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
  4. Motion Computing LE1600 Bluetooth Module Replacement, Bluetooth Module: Schritt 4, Bild 1 von 1
    • Unscrew hard drive panel using a Phillips head #1 screwdriver.
    • (Our device was not given to us with a hard drive or a hard drive panel)
  5. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 5, Bild 1 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 5, Bild 2 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 5, Bild 3 von 3
    • Pull clear plastic tab to detach hard drive from tablet.
  6. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 6, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 6, Bild 2 von 2
    • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
  7. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 7, Bild 1 von 1
    • Pull the brown tabs to disconnect the white ribbon cable on the other side.
  8. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 8, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 8, Bild 2 von 2
    • Caution: do not pull on the wires, instead pull from the plastic connectors.
    • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
  9. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 9, Bild 1 von 1
    • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
  10. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 10, Bild 1 von 1
    • Using a spudger, press in the five tabs on the side where the battery was.
    • This should separate the two halves of the device. Carefully set the side with the display off to the side.
  11. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 11, Bild 1 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 11, Bild 2 von 3 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 11, Bild 3 von 3
    • Locate the Bluetooth board.
    • Disconnect the ribbon cable by pulling on the plastic connector.
  12. Motion Computing LE1600 Bluetooth Module Replacement: Schritt 12, Bild 1 von 2 Motion Computing LE1600 Bluetooth Module Replacement: Schritt 12, Bild 2 von 2
    • Unscrew the 4mm screw holding the board onto the tablet.
    • Lift the board out of the tablet and carefully set it aside.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
David Troy
44 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 15-14, Forte Spring 2012 Mitglied von Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 2,365
