Einleitung
If you're having sound issues, your speakers may be broken. Follow these steps to replace them.
Was du brauchst
Slide the battery lock switch next to the power slider to the unlocked position.
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
Unscrew hard drive panel using a Phillips head #1 screwdriver.
(Our device was not given to us with a hard drive or a hard drive panel)
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
Using a spudger, press in the five tabs on the side where the battery was.
This should separate the two halves of the device. Carefully set the side with the display off to the side.
Locate the Bluetooth board.
Disconnect the ribbon cable by pulling on the plastic connector.
Unscrew the 4mm screw holding the board onto the tablet.
Lift the board out of the tablet and carefully set it aside.
Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
Unstick the white masking tape and the black electrical tape holding the black and red wire down.
Pull out the wire and speaker.
