Was du brauchst
Hold the phone with the back side facing you.
Press down on the silver tab towards the bottom end of the phone.
Carefully lift up the back casing to reveal the battery.
Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
The phone should now look like this.
Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
The cover will now pull off easily.
Use a plastic opening tool to pry between the front and back cover.
Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
Once all the clips have been freed, the front cover will lift away from the phone.
Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
Lift the keyboard frame away from the device.
Using a plastic opening tool, detach the connector on the LCD screen from the motherboard.
There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
Remove the LCD screen from the motherboard
Once the LCD screen is taken off, the motherboard is fully separated from the device.
