Zum Hauptinhalt wechseln
Sony Vaio VGN-TXN25N Display Screen Replacement
Was du brauchst
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: Schritt 1, Bild 1 von 2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: Schritt 1, Bild 2 von 2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 2, Bild 1 von 3 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 2, Bild 2 von 3 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 2, Bild 3 von 3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 3, Bild 2 von 2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 4, Bild 1 von 3 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 4, Bild 2 von 3 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 5, Bild 1 von 3 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 5, Bild 2 von 3 Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 5, Bild 3 von 3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the screen.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 5-3, Forte Spring 2012 Mitglied von Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 3,586
