Zum Hauptinhalt wechseln
Plantronics CS50 Headset Microphone Replacement
Was du brauchst
  1. Plantronics CS50 Headset Microphone Replacement, Battery: Schritt 1, Bild 1 von 3 Plantronics CS50 Headset Microphone Replacement, Battery: Schritt 1, Bild 2 von 3 Plantronics CS50 Headset Microphone Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Microphone Replacement: Schritt 2, Bild 1 von 3 Plantronics CS50 Headset Microphone Replacement: Schritt 2, Bild 2 von 3 Plantronics CS50 Headset Microphone Replacement: Schritt 2, Bild 3 von 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Plantronics CS50 Headset Microphone Replacement, Microphone: Schritt 3, Bild 1 von 2 Plantronics CS50 Headset Microphone Replacement, Microphone: Schritt 3, Bild 2 von 2
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. Plantronics CS50 Headset Microphone Replacement: Schritt 4, Bild 1 von 2 Plantronics CS50 Headset Microphone Replacement: Schritt 4, Bild 2 von 2
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  5. Plantronics CS50 Headset Microphone Replacement: Schritt 5, Bild 1 von 2 Plantronics CS50 Headset Microphone Replacement: Schritt 5, Bild 2 von 2
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  6. Plantronics CS50 Headset Microphone Replacement: Schritt 6, Bild 1 von 2 Plantronics CS50 Headset Microphone Replacement: Schritt 6, Bild 2 von 2
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  7. Plantronics CS50 Headset Microphone Replacement: Schritt 7, Bild 1 von 2 Plantronics CS50 Headset Microphone Replacement: Schritt 7, Bild 2 von 2
    • Slowly separate the motherboard from the rest of the headset.
  8. Plantronics CS50 Headset Microphone Replacement: Schritt 8, Bild 1 von 1
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  9. Plantronics CS50 Headset Microphone Replacement: Schritt 9, Bild 1 von 1
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
Abschluss
To reassemble your device, follow these instructions in reverse order. Replace the glue and solder where they are needed.
Cal Poly, Team 17-29, Amido Spring 2012 Mitglied von Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,763
