Zum Hauptinhalt wechseln
Eatsmart ESBS-01 Battery Replacement
  1. Eatsmart ESBS-01 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Eatsmart ESBS-01 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • The LO message on the screen indicates that your digital weight scale is running on low battery so you need to get the replacement battery.
    • This area is where the batteries located, top right corner of the scale.
  2. Eatsmart ESBS-01 Battery Replacement: Schritt 2, Bild 1 von 2 Eatsmart ESBS-01 Battery Replacement: Schritt 2, Bild 2 von 2
    • To open the battery compartment, use your finger to gentling push the tip to open the battery compartment.
  3. Eatsmart ESBS-01 Battery Replacement: Schritt 3, Bild 1 von 2 Eatsmart ESBS-01 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the old batteries from the device by pushing the battery toward the wire side and gentling taking it out.
  4. Eatsmart ESBS-01 Battery Replacement: Schritt 4, Bild 1 von 2 Eatsmart ESBS-01 Battery Replacement: Schritt 4, Bild 2 von 2
    • Insert the new batteries in the device.
    • Be aware to place the batteries in the right charge. The positive (+) and negative (-) signs are labeled inside the battery compartment. Place the flat side of the battery to the negative side and the little lip side of the battery to the positive side on the device.
  5. Eatsmart ESBS-01 Battery Replacement: Schritt 5, Bild 1 von 3 Eatsmart ESBS-01 Battery Replacement: Schritt 5, Bild 2 von 3 Eatsmart ESBS-01 Battery Replacement: Schritt 5, Bild 3 von 3
    • Put the cover of the compartment back. You successfully replaced the batteries.
    • You should now see the weight displaying on the screen after the replacement.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Elle Luo
137 Reputation
1 Anleitung geschrieben
UC Davis, Team S4-G1, Cole Spring 2017 Mitglied von UC Davis, Team S4-G1, Cole Spring 2017
UCD-COLE-S17S4G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 1,897
