Zum Hauptinhalt wechseln
Palm Treo 700P Motherboard Replacement
Was du brauchst
  1. Palm Treo 700P Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Palm Treo 700P Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Palm Treo 700P Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Motherboard Replacement: Schritt 2, Bild 1 von 2 Palm Treo 700P Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Motherboard Replacement, Back Case: Schritt 3, Bild 1 von 1
    • Remove the stylus from the phone.
  4. Palm Treo 700P Motherboard Replacement: Schritt 4, Bild 1 von 1
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P Motherboard Replacement: Schritt 7, Bild 1 von 2 Palm Treo 700P Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 Palm Treo 700P Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 Palm Treo 700P Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P Motherboard Replacement: Schritt 9, Bild 1 von 3 Palm Treo 700P Motherboard Replacement: Schritt 9, Bild 2 von 3 Palm Treo 700P Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P Motherboard Replacement: Schritt 10, Bild 1 von 2 Palm Treo 700P Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P Motherboard Replacement: Schritt 11, Bild 1 von 3 Palm Treo 700P Motherboard Replacement: Schritt 11, Bild 2 von 3 Palm Treo 700P Motherboard Replacement: Schritt 11, Bild 3 von 3
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Abschluss
Ivan
11 Reputation
1 Anleitung geschrieben
Cal Poly, Team 12-37, Regan Spring 2012 Mitglied von Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 807
