Zum Hauptinhalt wechseln
Disassembling Beaba Lutin night lamp
Was du brauchst
  1. Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: Schritt 1, Bild 1 von 3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: Schritt 1, Bild 2 von 3 Disassembling Beaba Lutin night lamp, Disassembling Beaba Lutin night lamp: Schritt 1, Bild 3 von 3
    • The lamp opens up at the base: there are two smaller tabs next to the button, the semi-transparent plasic can be pressed in a bit with a knife, put a bit of paper inbetween to prevent the clip from snapping back. Next go with a knife towards one of the large tabs on the side until one side snaps out. Repeat for other side.
  2. Disassembling Beaba Lutin night lamp: Schritt 2, Bild 1 von 3 Disassembling Beaba Lutin night lamp: Schritt 2, Bild 2 von 3 Disassembling Beaba Lutin night lamp: Schritt 2, Bild 3 von 3
    • Remove the 4 screws (warning: 2x2 different types), out comes the pcb. Detach battery connector at the back.
  3. Disassembling Beaba Lutin night lamp: Schritt 3, Bild 1 von 3 Disassembling Beaba Lutin night lamp: Schritt 3, Bild 2 von 3 Disassembling Beaba Lutin night lamp: Schritt 3, Bild 3 von 3
    • remove two more screws to get at the battery
  4. Disassembling Beaba Lutin night lamp: Schritt 4, Bild 1 von 1
    • Overview of parts
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
petur
508 Reputation
3 Anleitungen geschrieben
3 Kommentare
I think it is easier to open the lamp by pressing the semi-transparent part at the opposite side of the button.
Matthieu Morel - Antwort
How can I open the lamp??? Please post a photo of how are u using the knife because I can't!!!
Alberto Santaella Gallego - Antwort
you need to press the clips inward, the picture shows where the clips are. Slide inbetween and press
petur - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 56
Insgesamt: 3,490
