Zum Hauptinhalt wechseln
1986-1993 Volvo 240 Engine Air Filter Replacement
Was du brauchst
  1. 1986-1993 Volvo 240 Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 1
    • The engine air filter housing is located at the front of the engine bay, between the engine and the radiator.
    • Open the lid of the filter housing by releasing the metal clips along the edge of the lid.
  2. 1986-1993 Volvo 240 Engine Air Filter Replacement: Schritt 2, Bild 1 von 2 1986-1993 Volvo 240 Engine Air Filter Replacement: Schritt 2, Bild 2 von 2
    • Once the clips are released, pull the lid away from the air filter housing.
    • Grab the air filter and remove it from the filter housing.
    • Be sure to install the new air filter in the same orientation as the old one.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.503 Reputation
127 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 8,216
