Zum Hauptinhalt wechseln
iMac G5 17" Model A1144 RAM Replacement
Was du brauchst
  1. iMac G5 17" Model A1144 RAM Replacement, Access Door: Schritt 1, Bild 1 von 1
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
  4. iMac G5 17" Model A1144 RAM Replacement: Schritt 4, Bild 1 von 1
    • Slide the RAM chip straight out of its socket.
    • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 17,133
