Zum Hauptinhalt wechseln
DualShock 2 Wireless Controller Analog Stick Replacement
Was du brauchst
  1. DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: Schritt 1, Bild 1 von 2 DualShock 2 Wireless Controller Analog Stick Replacement, Analog Stick: Schritt 1, Bild 2 von 2
    • Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
  2. DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 2, Bild 1 von 2 DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 2, Bild 2 von 2
    • Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
    • Be mindful not to sever the connection between the battery pack attached to the back casing and the internal board
  3. DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 3, Bild 1 von 2 DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
  4. DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 4, Bild 1 von 2 DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 4, Bild 2 von 2
    • Lift the analog stick board away from the front of the controller.
    • Remove the detached or loose analog stick for realignment.
  5. DualShock 2 Wireless Controller Analog Stick Replacement: Schritt 5, Bild 1 von 1
    • Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
    • The stick may not immediately click into place under the pressure. Instead of pushing harder, try rotating the stick 90 degrees and pushing down again.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
Texas Tech, Team S1-G1, Rauch Summer 2017 Mitglied von Texas Tech, Team S1-G1, Rauch Summer 2017
TTU-RAUCH-SU17S1G1
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 34
Letzte 30 Tage: 205
Insgesamt: 12,127
