Zum Hauptinhalt wechseln
PlayStation 2 Slimline Optical Drive Replacement
Was du brauchst
  1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: Schritt 1, Bild 2 von 3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: Schritt 1, Bild 3 von 3
    • Remove the rubber feet on two of the screw covers on the bottom of the console.
    • Remove the screw covers and the screws themselves.
    • Caution: One of the screws is underneath the "Do not void" seal
  2. PlayStation 2 Slimline Optical Drive Replacement: Schritt 2, Bild 1 von 2 PlayStation 2 Slimline Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  3. PlayStation 2 Slimline Optical Drive Replacement: Schritt 3, Bild 1 von 3 PlayStation 2 Slimline Optical Drive Replacement: Schritt 3, Bild 2 von 3 PlayStation 2 Slimline Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
tlroesner
1.864 Reputation
4 Anleitungen geschrieben
3 Kommentare
How is it that this guide says difficult and the other PS2 drive replacement on here says easy?
Mark - Antwort
it really depends on your level of skill/experience.
Damien Simons -
How many different versions of drive is there for the slim model? When you go to replace it, do you just compare the model number on the laser?
Trevor V - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 91
Insgesamt: 22,080
