Zum Hauptinhalt wechseln
Cirago M9030 Screen Protector Replacement
Was du brauchst
  1. Cirago M9030 Screen Protector Replacement, Cover: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Screen Protector Replacement: Schritt 2, Bild 1 von 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Screen Protector Replacement: Schritt 3, Bild 1 von 2 Cirago M9030 Screen Protector Replacement: Schritt 3, Bild 2 von 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Screen Protector Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Screen Protector Replacement: Schritt 5, Bild 1 von 3 Cirago M9030 Screen Protector Replacement: Schritt 5, Bild 2 von 3 Cirago M9030 Screen Protector Replacement: Schritt 5, Bild 3 von 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Screen Protector Replacement: Schritt 6, Bild 1 von 3 Cirago M9030 Screen Protector Replacement: Schritt 6, Bild 2 von 3 Cirago M9030 Screen Protector Replacement: Schritt 6, Bild 3 von 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Screen Protector Replacement, IDE Connector: Schritt 7, Bild 1 von 2 Cirago M9030 Screen Protector Replacement, IDE Connector: Schritt 7, Bild 2 von 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Screen Protector Replacement: Schritt 8, Bild 1 von 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Screen Protector Replacement: Schritt 9, Bild 1 von 2 Cirago M9030 Screen Protector Replacement: Schritt 9, Bild 2 von 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Screen Protector Replacement: Schritt 10, Bild 1 von 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Screen Protector Replacement: Schritt 11, Bild 1 von 2 Cirago M9030 Screen Protector Replacement: Schritt 11, Bild 2 von 2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
  12. Cirago M9030 Screen Protector Replacement, Motherboard: Schritt 12, Bild 1 von 2 Cirago M9030 Screen Protector Replacement, Motherboard: Schritt 12, Bild 2 von 2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
  13. Cirago M9030 Screen Protector Replacement, Screen Protector: Schritt 13, Bild 1 von 1
    • Locate the plastic screen protector on the front cover.
  14. Cirago M9030 Screen Protector Replacement: Schritt 14, Bild 1 von 1
    • Grasping the sides of the cover, gently press on screen protector from the inside of the front cover to pop out the screen protector.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Sutardji
171 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 1-4, Regan SU 2012 Mitglied von Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 15
Insgesamt: 932
