Zum Hauptinhalt wechseln
Logitech Harmony 950 Motherboard Replacement
Was du brauchst
  1. Logitech Harmony 950 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Logitech Harmony 950 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Motherboard Replacement: Schritt 2, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 2, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Motherboard Replacement: Schritt 3, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 3, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Motherboard Replacement: Schritt 4, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 4, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
  5. Logitech Harmony 950 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
    • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
    • You need to repeat this process for both sides of the remote.
  6. Logitech Harmony 950 Motherboard Replacement: Schritt 6, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 6, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
    • Use the Angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
  7. Logitech Harmony 950 Motherboard Replacement: Schritt 7, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 7, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws.
    • Be careful not to detach the pink wires when removing the gold charging conductors.
  8. Logitech Harmony 950 Motherboard Replacement: Schritt 8, Bild 1 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 8, Bild 2 von 3 Logitech Harmony 950 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the black tape to access the cable underneath.
    • Use the Angled Tweezers to lift the black lock.
    • Slide the yellow cable to disconnect it from the circuit board.
  9. Logitech Harmony 950 Motherboard Replacement: Schritt 9, Bild 1 von 2 Logitech Harmony 950 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Pull the circuit board off of the remote from the bottom, and lift up to detach it from the cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S2-G2, Passmore Fall 2017 Mitglied von USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
How replace A Mitsubishi Remote Control
عبدالعزيز المناعي - Antwort
How replace A Mitsubishi Remote Control ?
Thanks
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 46
Insgesamt: 2,505
