Zum Hauptinhalt wechseln
Logitech Harmony 950 Battery Replacement
Was du brauchst
  1. Logitech Harmony 950 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Logitech Harmony 950 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Battery Replacement: Schritt 2, Bild 1 von 3 Logitech Harmony 950 Battery Replacement: Schritt 2, Bild 2 von 3 Logitech Harmony 950 Battery Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Battery Replacement: Schritt 3, Bild 1 von 3 Logitech Harmony 950 Battery Replacement: Schritt 3, Bild 2 von 3 Logitech Harmony 950 Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Battery Replacement: Schritt 4, Bild 1 von 3 Logitech Harmony 950 Battery Replacement: Schritt 4, Bild 2 von 3 Logitech Harmony 950 Battery Replacement: Schritt 4, Bild 3 von 3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G2, Passmore Fall 2017 Mitglied von USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
And where to buy these batteries?
Rene A - Antwort
Still no batteries for this unit? Maybe Amazon?
Dan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 46
Insgesamt: 4,789
