Einleitung
This guide will walk you through how to replace your button pad.
Was du brauchst
Remove the outer screen cover by releasing the top clip from the main body of the device.
Remove the battery cover by releasing the clip from the main body of the device.
Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
Use tweezers to remove the power button from the back case.
Disconnect the button pad by using the spudger to pry it off the motherboard.
Remove the button pad.
