Zum Hauptinhalt wechseln
BLU Life X8 Back Camera Replacement
Was du brauchst
  1. BLU Life X8 Back Camera Replacement, Battery: Schritt 1, Bild 1 von 2 BLU Life X8 Back Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Back Camera Replacement: Schritt 2, Bild 1 von 1
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Back Camera Replacement: Schritt 3, Bild 1 von 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Back Camera Replacement, Back Camera: Schritt 4, Bild 1 von 2 BLU Life X8 Back Camera Replacement, Back Camera: Schritt 4, Bild 2 von 2
    • Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
  5. BLU Life X8 Back Camera Replacement: Schritt 5, Bild 1 von 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from reengaging.
  6. BLU Life X8 Back Camera Replacement: Schritt 6, Bild 1 von 1
    • Once all the clips have been released, pull back the frame and set it aside.
  7. BLU Life X8 Back Camera Replacement: Schritt 7, Bild 1 von 1
    • Use the tweezers to unlock the ribbon cable from the motherboard
    • The ribbon cable should be free. Pull back on the ribbons to release it from the connector
  8. BLU Life X8 Back Camera Replacement: Schritt 8, Bild 1 von 1
    • Lift the back camera from its housing
    • The back camera may be glued to the phone
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S1-G2, Nance Fall 2017 Mitglied von USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 230
