Zum Hauptinhalt wechseln
HP Pavilion x360 m1-u001dx Battery Replacement
Was du brauchst
  1. HP Pavilion x360 m1-u001dx Battery Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 4, Bild 1 von 3 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 4, Bild 2 von 3 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 4, Bild 3 von 3
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 5, Bild 3 von 3
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 6, Bild 1 von 2 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 6, Bild 2 von 2
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 7, Bild 1 von 2 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 7, Bild 2 von 2
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx Battery Replacement, Battery: Schritt 8, Bild 1 von 3 HP Pavilion x360 m1-u001dx Battery Replacement, Battery: Schritt 8, Bild 2 von 3 HP Pavilion x360 m1-u001dx Battery Replacement, Battery: Schritt 8, Bild 3 von 3
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 9, Bild 1 von 2 HP Pavilion x360 m1-u001dx Battery Replacement: Schritt 9, Bild 2 von 2
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
Abschluss
Katie
549 Reputation
5 Anleitungen geschrieben
Ein Kommentar
What is the usual expected backup time for this battery?
Thanks for the instructions.
Nipu011 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 2,270
