Zum Hauptinhalt wechseln
Sony BDP-S3200 Disk Tray Belt Replacement
Was du brauchst
  1. Sony BDP-S3200  Disk Tray Belt Replacement, Sony BDP-S3200 Disassembly: Schritt 1, Bild 1 von 1
    • Remove all cables from the device.
  2. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 2, Bild 1 von 2 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 2, Bild 2 von 2
    • Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
  3. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 3, Bild 1 von 1
    • Pull the top cover off by sliding back from the device once the screws have been taken out.
  4. Sony BDP-S3200  Disk Tray Belt Replacement, Disk Drive Replacement: Schritt 4, Bild 1 von 1
    • Locate the disk drive
  5. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 5, Bild 1 von 3 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 5, Bild 2 von 3 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 5, Bild 3 von 3
    • Lightly lift off the hook on both front rear side and the bottom of the device to remove the front panel
  6. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 6, Bild 1 von 2 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 6, Bild 2 von 2
    • Remove the two screws that attach the disk drive to the frame using a #1 Phillips screwdriver.
  7. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 7, Bild 1 von 3 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 7, Bild 2 von 3 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 7, Bild 3 von 3
    • Carefully pull the (3) three bands off vertically.
    • NOTE: There is a latch that needs to be lifted off before pulling the band out for the middle band.
  8. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 8, Bild 1 von 2 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 8, Bild 2 von 2
    • Lift the disk drive off of the device
  9. Sony BDP-S3200  Disk Tray Belt Replacement, Disk Tray Belt: Schritt 9, Bild 1 von 3 Sony BDP-S3200  Disk Tray Belt Replacement, Disk Tray Belt: Schritt 9, Bild 2 von 3 Sony BDP-S3200  Disk Tray Belt Replacement, Disk Tray Belt: Schritt 9, Bild 3 von 3
    • Remove the top of the disk drive by gently lifting up on the four latches located on both sides of the disk drive while lifting upwards.
    • The latches are very thin and can break off easily so make sure to use caution when lifting them to remove the disk drive top.
  10. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 10, Bild 1 von 3 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 10, Bild 2 von 3 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 10, Bild 3 von 3
    • Slide out the disk tray.
    • If the disk tray does not come out easily don’t force it out this could break the gears that allow the tray to move. Gently lift the disk tray upwards while sliding it out.
  11. Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 11, Bild 1 von 2 Sony BDP-S3200  Disk Tray Belt Replacement: Schritt 11, Bild 2 von 2
    • Remove the disc tray belt.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S5-G2, Walkup Fall 2017 Mitglied von USF Tampa, Team S5-G2, Walkup Fall 2017
USFT-WALKUP-F17S5G2
5 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 646
