Einleitung
This is a simple step-by-step guide on how to remove and replace a battery for a Dell Inspiron 13-5368. You will need a Philips Head J-0 screwdriver and a pry tool in order to perform this task. It is very easy to do and will only take about 5 minutes.
Was du brauchst
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
I have this same question^. Can I reuse the cable from the old battery?
